| If you use the factory size one for the 300zx it will not work so great. 1: The slave cylinder will be hard to install and the clutch will the tob will drag on the clutch pressure plate. 2: The clutch pedal will be hard, because the tob is towards the outer fingers of the pressure plate and not the inner fingers. I will try to take pictures of my tob as i have a os triple plate in my z.
